Scholex Posted August 23, 2017 Report Share Posted August 23, 2017 Es posible comunicar por MODBUS un SAMBA que tiene puerto de comunicación V100-17-RS4 con un pc utilizando el cable RS232 y el MJ10-22-CS25 Quote Link to comment Share on other sites More sharing options...
MVP 2022 Joe Tauser Posted August 23, 2017 MVP 2022 Report Share Posted August 23, 2017 Quote Google translated: It is possible to communicate by MODBUS a SAMBA that has communication port V100-17-RS4 with a pc using the cable RS232 and the MJ10-22-CS25? Yes, this should not be a problem. The Vision Modbus Examples use the same code as the Samba. Joe T. Quote Link to comment Share on other sites More sharing options...
