Declan Posted October 21, 2017 Report Share Posted October 21, 2017 I recently installed the latest version of UniLogic 1.21.51 and everything seems to install ok but when I run the application I get an error before the application opens. I says that it cant find UniLogic Notifier or that it doesn't exist but I can see the file in the Unitronics Profile File folder. Any ideas please. Thank you ! Quote Link to comment Share on other sites More sharing options...
Saragani Posted October 21, 2017 Report Share Posted October 21, 2017 If I would have to guess, something in the SQL Server installation or SQL Instance, failed. What I would try to do is: 1. Close UniLogic if running 2. Start the Command Prompt As Administrator 3. Write Command prompt the following commands: sqllocaldb stop unilogic sqllocaldb delete unilogic sqllocaldb create unilogic 11.0 Then try running UniLogic again. Tell me if it helped. If not, then a remote session is required. Quote Link to comment Share on other sites More sharing options...
kld Posted April 26, 2019 Report Share Posted April 26, 2019 hi I have the same error message? I ma trying to download logic 1.25, Rev 61. I have used the diagnostic tool all checked ok. Thanks Kld Quote Link to comment Share on other sites More sharing options...
kld Posted April 26, 2019 Report Share Posted April 26, 2019 Hi. After rebooting ..The software is working. Have great weekend. Kld Quote Link to comment Share on other sites More sharing options...
