cha Posted February 6, 2018 Report Share Posted February 6, 2018 Hello iam located in Morocco and work in textile industry i made a program for washing machine using samba 7 and 4 ra 22 it s working well except for one think I am sure easy but I did not found yet I have a ta timer for washing time On my hmi display this timer is in mode enable keypad entry so I can change the washing time when I want but it s changing only preset time not current so I had a button to reset current time i wonder if there is a sb linked to the entry touch of the touchscreen keypad linked with this variable only timer ta that when pressed will reset the timer and enter the new value as current hope I was clear and thank you for your previous help charles Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 6, 2018 MVP 2021 Report Share Posted February 6, 2018 On your HMI timer there is a field called "Legal Entry". Link a MB to that field. That MB will turn on for one cycle after an entry is made to the timer preset. Use that MB to reset your timer. 1 Quote Link to comment Share on other sites More sharing options...
cha Posted February 6, 2018 Author Report Share Posted February 6, 2018 I knew it was simple as that but this morning I tried to put some load timer preset and make comparaison if different from ml then reset but without succes Dear Sir toda raba you made my day I am running on my knee to apply your solution Quote Link to comment Share on other sites More sharing options...
