plcfox Posted February 18, 2018 Report Share Posted February 18, 2018 We use a V350 to index a servo motor via the PTO built in feature works great. We just need a larger screen and would like to use the V700 to accomplish this found that it does not support the PTO built in the V350 the PTO features are helpful in the V350 as we can easily change things like ramp speeds etc. Just need some direction or better yet, Perhaps a forum member might have a V700 ladder net I could use to accomplish the same Thank you. Quote Link to comment Share on other sites More sharing options...
Kikis Posted February 20, 2018 Report Share Posted February 20, 2018 Hello, You could use EXF-RC15 high speed remote I/O module together with the V700. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted February 22, 2018 MVP 2021 Report Share Posted February 22, 2018 For that matter you could pop a CANbus card in the V350 and slave it off of the V700. Joe T. Quote Link to comment Share on other sites More sharing options...
Kikis Posted February 22, 2018 Report Share Posted February 22, 2018 Another solution is to leave your V350 running the program inside the control panel and install a new third party HMI unit of your preferred size. Modbus is an easy way to establish communication between the two devices. Quote Link to comment Share on other sites More sharing options...
plcfox Posted February 22, 2018 Author Report Share Posted February 22, 2018 My initial thoughts were to send a 8 bit (or 4) instruction call to the V350 from the V700 and use the V350 as the driver only to the Servo as the instruction are used for dispensing product that varies turns and velocity dependent on a request from a rfid fill request. I was just looking for other possible options seems like solutions point in a similar direction. A servo drive will also handle ramp values as a preset so I could re write something to work on the V700 but more complex Thanks to All PF... Quote Link to comment Share on other sites More sharing options...
