Romanwinter Posted March 7, 2018 Report Share Posted March 7, 2018 Hello, Is there any way to send an email with Data Table as a file? Or send by email some part of the data. Thank you Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted March 7, 2018 MVP 2021 Report Share Posted March 7, 2018 Yes. If you have an SD card in your PLC you can write a .csv file on it from the Data Tables using the SD function blocks. Then you can include the file name in the "Attached" field of the Send E-mail function block. Joe T. Quote Link to comment Share on other sites More sharing options...
Romanwinter Posted March 8, 2018 Author Report Share Posted March 8, 2018 Hello Joe, Thanks for the help. I found how to send a file via email and also managed to produce a CSV file, and I opened the file on my computer and everything is fine. But for some reason when I try to send it via email it comes either blank or as a dat. file, what it might be? And is there a any way to send an email with the utd file and then open on PC by Unitronics SD card suite software? Thank you Quote Link to comment Share on other sites More sharing options...
