Paolo Posted March 27, 2018 Report Share Posted March 27, 2018 Hi All, just only to confirm what I think...... In VisiLogic I need to use an delay off timer, but looking in the library instructions I didn't find a delay off timer.... I see only Delay On Timer (TD), Accumulated Timer (TA) and Extend pulse Timer (TE). Maybe I have to develop an TOff timer?? Or maybe I'm wrong?? Thanks in advance Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 27, 2018 MVP 2021 Report Share Posted March 27, 2018 Yes, those are the 3 timer types available - and those are all you need. You can create any other type of timer easily from those three. For a TOF, just use an inverted contact as the activating condition. Quote Link to comment Share on other sites More sharing options...
Paolo Posted March 27, 2018 Author Report Share Posted March 27, 2018 not enought......... Correct use an inverted contact as activating condition for the TD, but I need to insert an additional rung or net just to latch my coil with the same contact used to manage the TD and then reset the coil when the TD reached the time set. Anyway thanks for your support. Cheers Quote Link to comment Share on other sites More sharing options...
