Guest jonh Posted June 3, 2018 Report Share Posted June 3, 2018 hola... tengo un problema con mi plc v130 y no puedo recuperar el sistema operativo lo intento descargar pero aparece que tuvo un problema la conxion Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted June 3, 2018 MVP 2021 Report Share Posted June 3, 2018 Translated- hello ... I have a problem with my plc v130 and I can not recover the operating system I try to download but it appears that the conxion had a problem Please list more details - are you trying to use a USB converter? Joe T. Quote Link to comment Share on other sites More sharing options...
