PeterFukt Posted June 19, 2018 Report Share Posted June 19, 2018 Hello, with the latest batch of Samba SM35-J-T20 PLC's I've programmed, I have noticed that the buttons in the virtual keyboard stay pressed when you touch them once. I must touch them again to make the button appear unpressed. Is this a change in the firmware? It seems to work anyway. Just curious what is causing this. Buttons stay pressed with this PLC Firmware: 4.4 (28) Oct 16 2017 Bin library 0-2.10 (04) Buttons works normally with this PLC Firmware: 4.4 (09) Apr 5 2017 Bin library: 0-2.10 (03) Cheers, Peter Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted June 19, 2018 MVP 2021 Report Share Posted June 19, 2018 I have a Samba SM35-J-RA22 sitting on my desk right now. It has firmware 4.4 (45) Jan 2 2018 and does not do this. It also has Bin Library 0-2.10 (04). Quote Link to comment Share on other sites More sharing options...
PeterFukt Posted June 20, 2018 Author Report Share Posted June 20, 2018 It's the same phenomenon with a SM35-J-TA22 straight out of the box when I enter Info mode. Firmware: 4.4 (28) Oct 16 2017 Boot: 2.2 (24) Oct 29 2014 Bin library 0-2.10 (04) After updating the PLC the issue was resolved. Firmware: 4.4 (31) Oct 19 2017 Boot: 2.2 (48) Sep 25 2016 Bin library 0-2.10 (04) Quote Link to comment Share on other sites More sharing options...
