brian_swm Posted June 21, 2018 Report Share Posted June 21, 2018 Hello friends, I am new to Unitronics hardware and have about 1 year experience with ladder logic (studio 5000 up to this point). I am tasked with writing a program for a machine that uses the following components and I just need some help on choosing the right Unitronics PLC and what snap-in's I will need to work with the components: -conveyer belts (1 requires indexing/location tracking) -motor driving an actuator -motor moving a tray back and forth along rails -9 load cells I am leaning towards the Vision 350 TR20 currently, and it looks like the IO-LC3 module supports up to 3 load cells each, so I will need a PLC that supports at least 3 expansion ports (one for each IO-LC3) Also, in general I am wondering about how servos/motors are added to a program using Unitronics, it seems like there us usually a data bit to enable the servo (maybe controlling the power supply) and then a bit representing motor go/stop? Any help you all have is greatly appreciated, thank you in advance! Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted June 21, 2018 MVP 2023 Report Share Posted June 21, 2018 5 hours ago, brian_swm said: so I will need a PLC that supports at least 3 expansion ports (one for each IO-LC3) Initially you need to be going to this page: https://unitronicsplc.com/support-technical-library/ and scrolling to I/O & Com for Vision, and then looking at the IO-LC3 guides and also, more importantly, the guides listed under "I/O Expansion Module Adapters". The I/O modules connect together thus only using the one expansion port via the adapter. Before committing to anything have a good read of all the manuals for the possible options. cheers, Aus Link to comment Share on other sites More sharing options...
