Emrah AKAY Posted August 14, 2018 Report Share Posted August 14, 2018 Hello, I am from TESAN in İstanbul I want to use kiril alphabet with V570 I used two excel file and wrote turkish-kiril the cells... But I can't import from excel files for string library. It was to fault this display :''Excel file not valid, maybe change manually'' immediately please can you help me? If there is an example, will you send to me? Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted August 14, 2018 MVP 2021 Report Share Posted August 14, 2018 First of all - try to create two little librarys in different language. Than export it to two excel files and two CSV files. Please open this files by excel and see the structure. You must try to create new little file with te same sructure of data and import it to library. Please remember that system font do not provide cyrilic letter. You must install cyrilic font to visilogic to use it in menu and export - import cyrilic file. Quote Link to comment Share on other sites More sharing options...
Emrah AKAY Posted August 27, 2018 Author Report Share Posted August 27, 2018 Hi, I tried these directives but I didn't. It gives this warning: ''Failed to import strings from CSV, maybe import seperator is different from export seperator'' Please can you give me a project example ??? Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted August 28, 2018 MVP 2021 Report Share Posted August 28, 2018 I send for you blank project. I import to this project two librarys in different language (eng and ukr-cyrilic). This 1 and 2 lib files is exported from this project to CSV files - import seperator is ( , ). Please try to open blank project and import this two files into 1-st and 2-nd librarys. If import is OK - make your own CSV file with the same structure as my CSV file. Please install to visilogic cyrilic font before import files and choose this font in import process. 2_lib.csv 1_lib.csv LENGUAGE.vlp Quote Link to comment Share on other sites More sharing options...
