Chris Sweet Posted August 31, 2018 Report Share Posted August 31, 2018 This Vision 120-22-R1 has artifacts on the display.... pixels which are slightly lit up on the vertical mostly but the whole display is slightly dark. Power cycle does not seem to help. Any help would be greatly appreciated. Thanks,Chris Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted August 31, 2018 MVP 2021 Report Share Posted August 31, 2018 A picture would be nice to see the problem, but is this with your program loaded or with the plc empty? Try loading a complete program of nothing and see if the problem persists. If it doesn't, I have sometimes had this happen with HMI elements that are too close to each other. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Chris Sweet Posted September 4, 2018 Author Report Share Posted September 4, 2018 Thanks Ausman I did as you said and moved stuff around and all is well. Chris Quote Link to comment Share on other sites More sharing options...
