neurocyber Posted October 3, 2018 Report Share Posted October 3, 2018 I have a V700 as the scada panel. It runs on a drum and poles the slave for integers (Modbus IP) . This is working well with a cable. The question is can I use 2 wifi routers to connect the two plcs No pc, No internet needed. Thanks Greg Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted October 3, 2018 MVP 2021 Report Share Posted October 3, 2018 Yes, you should be able to do that with the proper setup of the routers. If the routers can communicate, then the PLCs should be able to also. Quote Link to comment Share on other sites More sharing options...
viscoelastic Posted October 3, 2018 Report Share Posted October 3, 2018 I also believe it will work. One router will have to be able to be changed from router to bridge mode. I would also use static ip’s on everything. Quote Link to comment Share on other sites More sharing options...
neurocyber Posted October 3, 2018 Author Report Share Posted October 3, 2018 Thanks, will attempt now that I know it most likely can be done, Greg Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted October 3, 2018 MVP 2021 Report Share Posted October 3, 2018 1 hour ago, viscoelastic said: One router will have to be able to be changed from router to bridge mode. I would also use static ip’s on everything. Yep, this is a good tip. Quote Link to comment Share on other sites More sharing options...
