mskoda Posted April 14, 2011 Report Share Posted April 14, 2011 Hi all! Anyone with same problem? Visilogic software crashes frequently on my machine with windows XP pro. Started to behave in that way since v. 9.0.1. I was hoping that 9.2.0. will solve issue, but it doesn't. Already tried reinstall several times... Cannot work... :-( Help Quote Link to comment Share on other sites More sharing options...
OSUstamm Posted April 18, 2011 Report Share Posted April 18, 2011 Hi all! Anyone with same problem? Visilogic software crashes frequently on my machine with windows XP pro. Started to behave in that way since v. 9.0.1. I was hoping that 9.2.0. will solve issue, but it doesn't. Already tried reinstall several times... Cannot work... :-( Help What happens when it crashes? Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted April 20, 2011 Report Share Posted April 20, 2011 Hello, Please delete the file “Current_OPLC.udb” from “C:\Program Files\Unitronics\Unitronics VisiLogic_C\Data\DB” Then try to run VisiLogic again. If after deleting the file the error still occurs, please reinstall VisiLogic as follow: For XP Please do the following: Backup your application files. Uninstall VisiLogic. Erase the “Unitronics” folder from- C:\Program Files Erase the “Unitronics” folder from- C:\Program Files\Common Files. Install VisiLogic again. Please let us know if it helped. Quote Link to comment Share on other sites More sharing options...
