MVP 2021 Ausman Posted February 16, 2019 MVP 2021 Report Share Posted February 16, 2019 Post moved here from a topic follow-on as worthy of new topic. Original post is this one: Hello I am trying to set up a V350 as a slave of a master device that uses Modbus ASCII. I understood that Visilogic does not handle Modbus ASCII. I want to get arround this by using a Modbus ASCII to Modbus RTU converter. However the master uses Modbus function code 22 (write multiple registers) and function code 23 (read, write multiple registers). Will the V350 understand these commands once converted to RTU? I only find function code 16 highest command when using V350 as a master. Does it understand command 22 and 23? Thanks David Quote Link to comment Share on other sites More sharing options...
