V290 Posted April 22, 2019 Report Share Posted April 22, 2019 when uploading file from V290 received the following error: Element does not exist IO-AI1X-A03X. I know that his is an expansion module, but how do I add it to the list? Quote Link to comment Share on other sites More sharing options...
DanT Posted April 23, 2019 Report Share Posted April 23, 2019 Hi; IO-AI1X-AO3X is not a valid I/O Module. What I/O Modules are attached to the unit? or Snap On Module What is the OS in the V290 ( and how old is it) and what version VisiLogic are you using? OS -- Touch Screen for 5-8 seconds, to get into Info Mode, enter 1111 and then go to system( up/down arrows) Dant Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted April 23, 2019 Report Share Posted April 23, 2019 take a look to this topic: Quote Link to comment Share on other sites More sharing options...
