Daniel_EWW Posted May 10, 2019 Report Share Posted May 10, 2019 Hi, can someone tell me how to import tags in a project which was created with "pre-defined tags"? (In this case we use the pre-defined tags because we are in progress to convert a V1210 project to the unistream) Thanks! Link to comment Share on other sites More sharing options...
Saragani Posted May 12, 2019 Report Share Posted May 12, 2019 It is currently not supported for predefined tags. I really don't suggest using the pre-defined template. Using actual tags and structs gives you much more power, but if you do need to import from Excel, then you can send the project and the excel file to the support, and one of the R&D guys will import the excel file into the project. Link to comment Share on other sites More sharing options...
Daniel_EWW Posted May 13, 2019 Author Report Share Posted May 13, 2019 Saragani, thanks for your answer and for your offer to send the project to the R&D guys. We will reconsider using the pre-defined template. Link to comment Share on other sites More sharing options...
