HAC Posted August 19, 2010 Report Share Posted August 19, 2010 Hi everybody, I download the program to the V570 with the V200-18-4XB and a IO ATC8 in response get illegal word operand access, when I reset the plc the screen just start blinking on and off; I turn off the plc take the card out and can reset plc then everything start normally, turn off intall the card and turn back on start normally again, but if I turn off the plc I have to start the cycle again ( turn off remove card etc. etc. ) Also check SDW60 and for time to time it comes up 1024 but not error code info in visilogic help menu. Options I try: 1- Reset the V570 to factory defalts 2- Download the program with Visilogic 8.6.0 and 8.6.1 3- Download the program without the cards Does anybody can give me an idea how to solve this problem? Any help will be greatly appreciated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted August 22, 2010 Report Share Posted August 22, 2010 Hello, Which V570 you have? T20, T34... Meanwhile, try as follow: 1. Turn off the PLC 2. Touch and hold the screen 3. Power on while screen touched 4. Touch twice in Bootstrap screen 5. Update the o/s 6. Download empty application to the controller. Let us know your results! Quote Link to comment Share on other sites More sharing options...
HAC Posted August 31, 2010 Author Report Share Posted August 31, 2010 Hi R. Mozes, sorry for the late response I'm been working on the field; I did have to change the V570 for the V350 to can complete my project on time. The V570 I'm using is the T20B. As soon as I can I will be trying your recomendation and I will posting the results. Thanks for your response. Quote Link to comment Share on other sites More sharing options...
HAC Posted April 25, 2012 Author Report Share Posted April 25, 2012 Hi R. Mozes, sorry for the late response I'm been working on the field; I did have to change the V570 for the V350 to can complete my project on time. The V570 I'm using is the T20B. As soon as I can I will be trying your recomendation and I will posting the results. Thanks for your response. Hi everybody: 1) Run OS update, download empty application everything runs normally. 2) Download application with V200-18-E3/4EX card everything fine. 3) Turn OPLC off plug in card, turn on and the screen start blinking (no programming downloaded). 4) Turn OPLC off unplug card, turn OPLC back on. Result: V290/V570 (T20B) O.S. (Stop Mode - Fatal Error) Enum:0x00000000 00000000 IP:0x00019CDE 0009C8F6 Ldr:0x00001FF0 Desc:Illegal Word Operand Access Quote Link to comment Share on other sites More sharing options...
