KCR Posted June 18, 2019 Report Share Posted June 18, 2019 Hi, I am seeing Ethernet/IP connections issues on multiple Unistream panels with the latest Unilogic firmware 1.26.90. On some systems i will see random disconnection errors that were not seen on the older 1.18.60 firmware. On the current 1.26.90 if i purposefully disconnect a Ethernet/ip device and reconnect to the Unistream it will not automatically connect. I need to cycle power/ reset the panel for communications to re-establish. Anyone else experiencing these issues? Quote Link to comment Share on other sites More sharing options...
NoamM Posted June 19, 2019 Report Share Posted June 19, 2019 Hi KCR, Please open a ticket at Unitronics "Help center" at https://support.unitronics.com/index.php the Support team will assist. Quote Link to comment Share on other sites More sharing options...
