bjarni Posted August 14, 2019 Report Share Posted August 14, 2019 Hello, wonder if you have some hint for me. I have a an Unistream with remote IO: Ex-RC1, LC3 and D16A3-R016, all hooked together via CAN bus I followed the config instructions from your training video, starting with an VisiLogic file from your examples. But when I try to load the exported .ulri file in the Ex-RC1 properties window it is like nothing happens, no warning or error messages and the Visilogic File field remains empty ? Thanks, Bjarni Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 14, 2019 Report Share Posted August 14, 2019 You are correct. There is an issue with that feature in the official version and it was already fixed for next version. There is a fix for this issue, either by a dll replacement, or an updated version of 1.26 (I need to check that). I'll be able to check this if there is an updated 1.26 version only tomorrow, and I'll give you a solution. Quote Link to comment Share on other sites More sharing options...
bjarni Posted August 15, 2019 Author Report Share Posted August 15, 2019 Thanks, I'll just wait. Quote Link to comment Share on other sites More sharing options...
Alon Avivi Posted August 15, 2019 Report Share Posted August 15, 2019 Hi, as a temporary solution please paste the VisiLogic file in the Unitronics main folder and also in the 1.26.90 folder. The file will imported. Quote Link to comment Share on other sites More sharing options...
bjarni Posted August 15, 2019 Author Report Share Posted August 15, 2019 Hi Alon Avivi, don't know which folders you are referring to. You got some full paths? and should I load the file from there? Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 15, 2019 Report Share Posted August 15, 2019 the installation folder where the exe of UniLogic is located. Alternatively, you can use the following DLL (replace the original DLL in your UniLogic installation directory). This DLL is for version 1.26.90 Unitronics.HardwareConfiguration.UI.dll Quote Link to comment Share on other sites More sharing options...
bjarni Posted August 15, 2019 Author Report Share Posted August 15, 2019 Great - thanks. it works now Quote Link to comment Share on other sites More sharing options...
