syafiq Posted December 2, 2019 Report Share Posted December 2, 2019 Greeting, I want to ask whether V130 can accept 2 type of analogue input if im using external analogue module or not. 2 (0-10v) analogue signal to PLC and another 2 (4-20 mA) analogue signal to external analogue module. Is it possible with V130 PLC Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted December 2, 2019 MVP 2023 Report Share Posted December 2, 2019 Absolutely. Several of the V130 models have onboard analog inputs and you can add an IO-ATC8 on the expansion port which gives you 8 more 14 bit inputs. With this in mind, you may want to dial back on the V130 you use as the models with analog inputs can be more expensive. Do you have a total I/O definition yet? Joe T. Quote Link to comment Share on other sites More sharing options...
