Patrick95 Posted February 6, 2020 Report Share Posted February 6, 2020 Hello, I'm having trouble setting time and date using function "set plc time and date" from network. The time and date are read from the network but not written to the PLC. version: unilogic: 1.28.34 panel: 1.28.58 I used the example: "UniStream_070_RFC_1305_UDFB._419_bck.ulpr". Thank you Link to comment Share on other sites More sharing options...
Pista Posted February 13, 2020 Report Share Posted February 13, 2020 Hi, After upgraded to version 1.28.34 try to upgrade CPU FPGA. There are changes in RTC in this version. UniLogic_Version_Changes.pdf RTC /GMT: UniStream now supports two clocks, Local Time and GMT. You can use these in Ladder elements, HMI Widgets, and set them via UniApps. A new parameter has been added to the RTC struct, Time Zone Existing Ladder functions Set PLC Time/Date now have a new parameter, Status. New System structs have been added, UTC Time and UTC Date We had this problem with the USC-P-B10 and now works OK. Link to comment Share on other sites More sharing options...
