Jimbob Posted July 5, 2011 Report Share Posted July 5, 2011 Hi, I have come across what seems to me to be an anomoly. I have a screen with 4 variables I can press the enter button to tab through the variables without entering a new value. However one variable always sticks and requires a new value as if the value displayed is wrong. After much messing around it seems to be associated with the "enable limits" option if its off no sticking I have linearity settings display -10 to 190 MI 0 to 16383 I have Limits of -8 to 90 (display value referenced) this sticks If I combine the axis with limits -8 to 9011 all is well. It appears to me the PLC is checking against Display values on data entry and MI values on subsequent edit Is this correct or am I talking rubbish your view would be appreciated. regards Jim Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted July 5, 2011 Report Share Posted July 5, 2011 Hi, In order for me to investigate this problem please send the application to Support@unitronics.com. Add detailed instrucitons how to recreate the problem. Also, what exactly do you mean by "stick"? Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted July 6, 2011 Report Share Posted July 6, 2011 It seems that there is a conflict in the variable settings. Since the limits of the input are -8 – 90, you do not need a format of xxx.x. if you are using this format you are required to enter zeros first. Quote Link to comment Share on other sites More sharing options...
