Daniel_EWW Posted July 3, 2020 Report Share Posted July 3, 2020 Hi, is it possible to set the CPU Ethernet (IP Address, Subnet, Gateway) and ModbusTCP (IP Address, Port) parameters with a .ini file? Please can you provide a file syntax example for the above metioned parameters? Thanks, Daniel Quote Link to comment Share on other sites More sharing options...
