Potenza Posted August 25, 2020 Report Share Posted August 25, 2020 I have just connected up Unilogic PLC USC-B5-T24 to do test. I have updated firmware and downloaded just a couple of lines of logic which was fine . I then changed those lines and now just get error when trying to download. Can anyone help. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted August 25, 2020 Report Share Posted August 25, 2020 Please post your test project. It may include errors in Ladder. Quote Link to comment Share on other sites More sharing options...
Potenza Posted August 25, 2020 Author Report Share Posted August 25, 2020 Hi Alex, I only have two lines of ladder I0 Set O0 I1 Reset O0 I did compile and build , no errors no warnings. The only difference is I deleted two tags which I had set and reset output. Quote Link to comment Share on other sites More sharing options...
