WamEng Posted September 2, 2020 Report Share Posted September 2, 2020 Is it a problem to have three Unican Send commands in parallel?? All triggered by the same .5sec oscillator.? I suspect that they should each be on a dedicated rung with timing between them. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted September 4, 2020 MVP 2021 Report Share Posted September 4, 2020 You should be able to do that. Have you given it a try? You can post your program as well so we can have a better look at what you're doing. Joe T. Quote Link to comment Share on other sites More sharing options...
