hane6 Posted August 27, 2010 Report Share Posted August 27, 2010 the forum has been said about this odd activity with linearizition. it seems that in "Help" there is example, which operates correctly only with 1 measurement. In "examples" there is actually working solution several measurements.! Today I spent 8 hours at work to investigate this thing, because the action was very strange... It seems that timing is very important with these utilities, I recommend that the "help"- files are updated as soon as possible Quote Link to comment Share on other sites More sharing options...
Emil Posted August 28, 2010 Report Share Posted August 28, 2010 Dear Hane6, In U90Ladder > Help menu > Sample U90 projects > Flow and toalizing there is a working example "Linearization of two inputs" (attached to the post too). Did you check it? Do you face any problem with it? Linearization of two inputs.U90 Quote Link to comment Share on other sites More sharing options...
hane6 Posted September 3, 2010 Author Report Share Posted September 3, 2010 Dear Hane6, In U90Ladder > Help menu > Sample U90 projects > Flow and toalizing there is a working example "Linearization of two inputs" (attached to the post too). Did you check it? Do you face any problem with it? Thank you.. No longer any problem. Problem was, that I looked first to the "HELP" file, and it led astray, untill i notice, that did'nt work. Example in "examples"- folder works. Quote Link to comment Share on other sites More sharing options...
