Ruarker Posted October 16, 2020 Report Share Posted October 16, 2020 Hi to everyone! I need to upload program from old v120-22-T40, in order to replace it with v130. Problem is, there is no such model in recent versions of Visilogic, I tried the oldest version I have, 4.5.4, and v120-22-T40 is not there also. This model is present in the Elementslist, and there is a description file for it in HW Cfg, I assume it is blocked somehow in the software. Can anyone suggest, where can I download older versions of Visilogic to try, or maybe there is another way to solve this problem ? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted October 17, 2020 MVP 2021 Report Share Posted October 17, 2020 Are you sure the program is able to be uploaded? It may not have been initially programmed to allow this. What messages are you getting during your attempts? cheers, Aus Quote Link to comment Share on other sites More sharing options...
Ruarker Posted October 17, 2020 Author Report Share Posted October 17, 2020 Yes, I'm sure, Upload goes normal, as usual, without any errors or restrictions, but at the end of the upload when usually goes Verify stage, it shows error message, something like "v120-22-T40 not found" and upload terminates. So, at first I want to try earlier versions, but can't find any. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted October 17, 2020 MVP 2021 Report Share Posted October 17, 2020 OK. I think your best bet here is to contact support. Either create a ticket using the support link at the top of the page, or support@unitronics.com Good luck and please return with the solution that worked. cheers, Aus Quote Link to comment Share on other sites More sharing options...
