kpetro07 Posted October 18, 2020 Report Share Posted October 18, 2020 Hello, I am looking for the best solution in order to store bits values and temperature(int16) with timestamp every time the bits are changing values. Just to keep a log to see the changes. Indexed Data table ? Or is there any 'easy' solution ? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted October 18, 2020 MVP 2021 Report Share Posted October 18, 2020 No easy out. The Data Table is the way to go. Joe T. Quote Link to comment Share on other sites More sharing options...
