rupeje Posted November 12, 2020 Report Share Posted November 12, 2020 Hello all, I tried searching but couldn't find this exact question. Is there a preferred cable to connect a laptop USB port to the RJ11 port on a V120? This is for program changes only. This is more of a quick favor so would rather purchase the correct cable than build a custom one. I have a USB/RS232 serial adapter (DB9) already if that's half the battle. Thanks so much! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted November 12, 2020 MVP 2021 Report Share Posted November 12, 2020 The correct part number you need is RS232-CB1, which includes the cable and the MJ10-22-CS25 adapter. Quote Link to comment Share on other sites More sharing options...
rupeje Posted November 12, 2020 Author Report Share Posted November 12, 2020 Thanks Flex! Quote Link to comment Share on other sites More sharing options...
