ORSO2001 Posted January 7, 2021 Report Share Posted January 7, 2021 Dears, by the "SD MANAGEMENT" I can select the max files stored in each folder...so the PLC will automatically erase the older files when the limit is exceeded...how to know when this will happens?...is a BIT that I can check or I have to take in care the files count? thanks Quote Link to comment Share on other sites More sharing options...
NoamM Posted February 8, 2021 Report Share Posted February 8, 2021 Dear ORSO2001, The "SD Management" procedure initialed every 60s. There is no BIT to check it. Quote Link to comment Share on other sites More sharing options...
