  • MVP 2022
It looks like you use panel as master and engine as slave.
Master named ID1   and  you try to read data from slave ID1 --- it is not correct.
Please change this nodes to different ID and try to read needed data.
You can change ID on engine to 2 or if it imposible - change master PLC ID to another one.
  • MVP 2022
Please post your modbus setup. Motor and drive nameplate and how modbus wires is connected to V700.  Sometimes A & B RS485 wire is swaped.
If you use USB connection to V700 - com port 1 is not work with modbus - it is connected to USB and Visilogic.
If it possible please use PC Modbus software and USB to R485 connection for test drive communication.
Please note - In drive parameter - you must configure communication settings drive ID  and enable Modbus communication.
