Jorge.dj Posted February 16, 2021 Report Share Posted February 16, 2021 Buenos días tengo un problema con el plc unitronic V570 no inicia se queda en pantalla color naranja con este mensaje. (factoy boot boot error) quisiera saber a qué se debe el plc es usado y que debería hacer o si se puede salvar el programa y volver a reprogramarlo gracias Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 16, 2021 MVP 2021 Report Share Posted February 16, 2021 Moved to the correct forum. Have you looked at this sticky at the top of this forum? Quote Link to comment Share on other sites More sharing options...
