2rlp Posted August 1, 2011 Report Share Posted August 1, 2011 Hi, Is it possible to use any of the Vision series PLC to print a Graphical Logo using an Ink Jet Printer? How? Thanks & regards Ron Quote Link to comment Share on other sites More sharing options...
Ofir Posted August 1, 2011 Report Share Posted August 1, 2011 Hi, It seems that printing the graph directly to the printer can be done using FB Protocol. If the printer has serial interface (RS232) and supports ASCII (DOS mode), the communication can be established via FB Protocol and this is relatively easy task. If the printer is “network unit” and is connected via Ethernet, it usually has its own set of commands. Probably printing a logo will be according to x and y cordinates and the relevant commands of the printer. Quote Link to comment Share on other sites More sharing options...
