Gábor Töreky Posted April 26, 2021 Report Share Posted April 26, 2021 Dear Al,, I have no experience with LD, I usually wita in ST, and I have problem with LD sequence logic. I would like to program the follow sequence: There are two machine, and they would like to send data to SQL at same time. Machine_1_Prod means Machine 1 would like to send, and Machine_2_prod means Machine2 would like to send data. xWriting means sending is active, and the SQL routin is sending the information (in another region) My problem is, that if Machine_1_Prod and Machine_2_prod is true at same time, that only Machine 2 send the information, and I don't know why. Is there any problem with this sequence. Row 2 is running before xWriting_product was set in row 1? Do you have any idea for solution? Best regards, Gábor Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted April 26, 2021 MVP 2021 Report Share Posted April 26, 2021 I do not know how Unilogic do with point 2 and 3 in 1st line (or 2nd). Can you try to: - place line 3 before 1 and 2 - play with 1-2 or 2-1 variant chagover - try to count Idebug for 1st an 2nd machine separately I think you must do something like State machine for send 1st and 2nd step by step. Signal from 1st. or 2nd -- activate State machine. Sate machine try send only first (if not active skip 1st step). After 1st send timer is OFF (or skip step) - activate 2nd send (if active). if timer for second one is off (or skip step) - then RESET State machine. Quote Link to comment Share on other sites More sharing options...
