Naskovic Posted May 18, 2021 Report Share Posted May 18, 2021 Hello everyone, I have a problem whit pulse train output, I use PTO to control servo drive . On this application i have a two segment of one step. First step have 400 pulses and 1500 velocity. Second segment have 800 pulses and 5000 velocity. The problem is on delay between first and second segment. This delay is acc 0.75 sec. I configured two function block whit above note mentioned parameters. I detected this problem when connected oscilloscope on high speed output on IO card. I need to make application to work continuously without delays . Do you know what is happened ? Could you please help mi to solve a problem? Thank you in advance! Quote Link to comment Share on other sites More sharing options...
AlexUT Posted May 18, 2021 Report Share Posted May 18, 2021 Please send your request with detailed explanation to support@unitronics.com Quote Link to comment Share on other sites More sharing options...
