A.a.p Posted June 16, 2021 Report Share Posted June 16, 2021 Hi, I am new to unitronics systems so i need a little help is it possible to make a program so I can set start and end point of an water probe. It gice a signal 4-20mA. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted June 16, 2021 MVP 2021 Report Share Posted June 16, 2021 Look at the Help tab and then open Sample U90 Projects. Look under Flow, totalizing and pump control for some tips The help files have lots of information that you will need in your learning curve. Quote Link to comment Share on other sites More sharing options...
