Fabios Posted June 22, 2021 Report Share Posted June 22, 2021 Hi, with vision/samba plc, how is possible to read NTC10K temperature sensor? BR Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted June 22, 2021 MVP 2021 Report Share Posted June 22, 2021 standard solution https://robertoweninc.com/4-20ma-plc-thermistor-measurement/ direct with hook up table linearization needed http://www.tri-plc.com/appnotes/F-series/F16160BAThermistor.pdf But +10V must be prepeared via some add cirquit. Quote Link to comment Share on other sites More sharing options...
