christopher Posted August 19, 2021 Report Share Posted August 19, 2021 Hi, I'm new to Unitronics, and I just got my self a 350 to play with for a control system. Is there a super easy way to create status HMI for DIO? Just a simple LED like many PLC's have would been nice to put on the display. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted August 20, 2021 MVP 2021 Report Share Posted August 20, 2021 Look at the Binary Image graphic object - You can pick different pictures for ON and OFF and link it directly to your I/O address. Joe T. Quote Link to comment Share on other sites More sharing options...
christopher Posted August 20, 2021 Author Report Share Posted August 20, 2021 Thanks, I've looked into that, but I still have to add all IOs as seperate HMI-objects. I guess it's possible to store all inputs in a vector, but as long as the outputs are single bits or numerical it doesn't really make any difference. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted August 24, 2021 MVP 2021 Report Share Posted August 24, 2021 On 8/20/2021 at 8:56 AM, christopher said: Thanks, I've looked into that, but I still have to add all IOs as seperate HMI-objects. That is true. When I do this I generally do a copy/paste and then edit the copies to get it knocked out faster. Joe T. Quote Link to comment Share on other sites More sharing options...
