DanT Posted September 2, 2021 Report Share Posted September 2, 2021 Hi; Looking for a bit of experienced guidance for a customer in setting up the Ethernet/IP Parameters and structures for using an Keyence IV2G30F Module. Anyone set one up with a UnIStream PLC? - Your experience? Have got the Module information for connecting to an A-B PLC, has some data there, DanT Quote Link to comment Share on other sites More sharing options...
AlexUT Posted September 5, 2021 Report Share Posted September 5, 2021 DanT, Do you have EDS file for module? Import it and if there are no errors - required structures will be created. Quote Link to comment Share on other sites More sharing options...
DanT Posted September 8, 2021 Author Report Share Posted September 8, 2021 Hi; I was able to locate the EDS Sheet in the Keyence website, extracted it, and UniLogic imported the data successfully. Info passed on to customer. DanT Quote Link to comment Share on other sites More sharing options...
