Bela Varga Posted October 1, 2021 Report Share Posted October 1, 2021 I recieved a V350 for an university SBR project to controll peristaltic pumps and air pumps based on external sensor data. My plan is to supply 230VAC and switch O1 - O4 outputs. Can I simply use the 230 VAC relay outputs to turn on/off 2 pc of appr. 6W motors or it would be too much load for the internal relays? I am currently learning the programming as well, but I have to tell if we need to order extra relays (or I/O expansion modules) for this application. Thank you in advance for help! Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted October 1, 2021 MVP 2021 Report Share Posted October 1, 2021 You can use internal relay to control 230VAC low power actuators. Please read instalation manual and add some fuses to controlled cirquit. Quote Link to comment Share on other sites More sharing options...
