Sebaster Posted December 6, 2021 Report Share Posted December 6, 2021 New here, so first of all, Hi there So, I've been working on the vision 130, I've to check temp from a trial workbench, soo on a certain event (ej no power supply) need to take the time left or current time from that timer and save it. Would like to know if is possible, and also if is possible to stop a timer and use the time left, or set a specific time from a MI variable. Thanks all so much Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted December 6, 2021 MVP 2021 Report Share Posted December 6, 2021 Please use demo project from Visilogic V120_Store_Load_Timer_or_Counter.vlp from Function example. For store timer time left SB2 -|/|- system bit can be used. After power on SB2 -| |- can restore timer value. V120_Backing_up_a_HSC.vlp demo Project in Visilogic is helpful for understand how to store-restore operation work. Quote Link to comment Share on other sites More sharing options...
