Dov Grobgeld Posted December 9, 2021 Report Share Posted December 9, 2021 Has anyone tried to compile MicroPython with the C-compiler of any of the Unitronics boards? Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted December 9, 2021 MVP 2021 Report Share Posted December 9, 2021 As i know Unistream board run under linux. I think Unistream not provide command line option on screen - It is Linux Based HMI+PLC. Maybe remote terminal is possible, but it is Unitronics "know how". Quote Link to comment Share on other sites More sharing options...
Dov Grobgeld Posted December 10, 2021 Author Report Share Posted December 10, 2021 I didn't realize they run a full OS. I thought it was just a MicroController. But even if they don't allow terminal access, if you can run a C-program, then perhaps you can compile MicroPython or LUA to run on it? I'd like to give our junior programmers a text based scripting programming environment. Quote Link to comment Share on other sites More sharing options...
