roghenr Posted January 10 Report Share Posted January 10 Good Morning. I want to use io-d18-ro8, is it mandatory to make a subroutine to use the addresses and create in Hw Configuration Subroutines? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 10 MVP 2021 Report Share Posted January 10 No, that selection is only to provide the ability to modify the HW configuration without reloading a program into the PLC. For normal I/O, just go to the HW Configuration in the upper left corner of VisiLogic and select your I/O module. The I/O addresses will be assigned and you can label and use them in your program in the same way you use any contact or coils. Quote Link to comment Share on other sites More sharing options...
roghenr Posted January 11 Author Report Share Posted January 11 21 hours ago, Flex727 said: Não, essa seleção é apenas para fornecer a capacidade de modificar a configuração de HW sem recarregar um programa no PLC. Para E/S normal, basta acessar a Configuração de HW no canto superior esquerdo do VisiLogic e selecionar seu módulo de E/S. Os endereços de E/S serão atribuídos e você pode rotulá-los e usá-los em seu programa da mesma forma que usa qualquer contato ou bobina. thank you so much i'm new to unitronics and i'm programming Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 11 MVP 2021 Report Share Posted January 11 1 minute ago, roghenr said: thank you so much i'm new to unitronics and i'm programming You may want to take advantage of the numerous videos & webinars Unitronics has available to help you learn how to use VisiLogic. Also, many example programs came with your VisiLogic installation that show you how to perform basic tasks. Quote Link to comment Share on other sites More sharing options...
