Damian Posted August 19, 2011 Report Share Posted August 19, 2011 I have a sampling of Unitronics hardware that I keep on hand for aid in demoing and development. I tried to remove a V200-18-E3XB from the back of my V570 and snap it into my V1040 and to my suprise ................ it doesn't fit. I had another V200-18-E3XB that I keep on hand as spare. That does fit. Upon inspection, I found the following. 1) The PC board of the original snap in module has extended corners that interfere with the studs of the V1040. 2) The PC board of the newer IO module has those corners removed. 3) The plastic studs on the V1040 are much longer than those on the V570 Why are the studs on the V1040 so much longer? The reason I ask is I want to know if it was intentional for some kind of hardware incompatibility. I want to know if I can cut the corners off my old module so that I can still continue to use it as a demo with the V1040. D Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted August 21, 2011 Report Share Posted August 21, 2011 Dear Damian, Yes you are right! The first batch of V1040 was having some hardware incompatibility which already fixed. You can cut the standoff. Cheers, Quote Link to comment Share on other sites More sharing options...
Damian Posted August 21, 2011 Author Report Share Posted August 21, 2011 Dear Damian, Yes you are right! The first batch of V1040 was having some hardware incompatibility which already fixed. You can cut the standoff. Cheers, Thank you. Quote Link to comment Share on other sites More sharing options...
