Ahti Posted January 23, 2022 Report Share Posted January 23, 2022 I use Unistream data converter suite - Trend to PDF. I have 4 difernet values in same graph. When I convert then all the values in y scale ends with differnet value and it is complicated to compare them with eathother. How I can set same maximum vale in y scale for all 4 values I have. A example 0-3. Or one value 0-3 and alla others 0-2 if it is possible. At the momet they have 0-2,355 and 0-1,268. Can I use curve properties file for that and can someone say what I should wiritte in this file? Or where I can get it? Quote Link to comment Share on other sites More sharing options...
Ahti Posted January 24, 2022 Author Report Share Posted January 24, 2022 Example result of conversion is attached! graafik3.pdf Quote Link to comment Share on other sites More sharing options...
Ahti Posted February 11, 2022 Author Report Share Posted February 11, 2022 So I asked it from Unitronics support! I googled it many times and no place found where you can get this information. And they describe how to make this file. I add the example with file with 4 values what I used. Tab should be between labels and nr. All symbols are not allowed. Now I got what I needed. curve data.txt Quote Link to comment Share on other sites More sharing options...
curtharrington1 Posted December 29, 2022 Report Share Posted December 29, 2022 On 2/11/2022 at 3:37 AM, Ahti said: So I asked it from Unitronics support! I googled it many times and no place found where you can get this information. And they describe how to make this file. I add the example with file with 4 values what I used. Tab should be between labels and nr. All symbols are not allowed. Now I got what I needed. curve data.txt 61 B · 7 downloads Here is the format if anyone is interested: [Trend Tag] [min range] [max range] Quote Link to comment Share on other sites More sharing options...
