roghenr Posted January 27, 2022 Report Share Posted January 27, 2022 ood Morning. I'm not succeeding in linearizing the following: distance meter, where: 4mA=0mm 20mA=2225mm is measuring level and when it rises it decreases value minimum value for work = 1700mm maximum value filled 1600 mm above overflow level alarm sounds. in the graph I want to show level rising up when the measurement value decreases in mm show minimum level for work = 1700mm max level = 1600 full oven thanks for the help V130-33-ta24 14-bit resolution Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted January 29, 2022 MVP 2021 Report Share Posted January 29, 2022 answered in your "wrong reading distance" topic. Quote Link to comment Share on other sites More sharing options...
