Restore Points
Flex727
The new feature in VisiLogic involving Restore Points is nice, but it needs some work:
1) Provide a way to turn the feature off completely if the user doesn't want or need it.
2) The Restore Points apparently take up significant memory because I keep getting messages to delete some. Make that automatic - the oldest ones need to roll off automatically.
3) Allow the shift or control key to be used to select more than one Restore point for deletion. Deleting each of them one at a time, with the confirm prompt, is a pain.
