UMD-0015E-B3 servo drive input voltage of 480?
MAVRIX
Manual say 380-440VAC +10% - 15%.
440VAC+10%=484VAC.... It is possible maximum. Main problem - internal or external brake resistor can be burned if value above 480 is happened.
Then you must ask support for information. Maybe Unitronics can provide customised servo with extended voltage range.
