baran Posted March 9, 2022 Report Share Posted March 9, 2022 hi everyone, I have a problem about my v570 controller. i am trying to communicate advantech adam 4572 rs485 to ethernet converter but cant reach. i can see tx and rx packages at configuration utility when i scan the slave id (advantechs program) but cant find the modbuss adress in the program. then later i am going to take this variables to my indusoft scada. Trying for 3 days Best regards. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted March 9, 2022 MVP 2021 Report Share Posted March 9, 2022 So, as I understand it, Adam has to read data from the V570 RS485 (or RS232) and broadcast it to the Ethernet. In my opinion, the best solution is to buy a standard Ethernet card for the V570 PLC and connect it to SCADA via Modbus TCP. P.S. Your connection method is also possible, but I can't give you more information because I don't have the Adam module available. Quote Link to comment Share on other sites More sharing options...
baran Posted March 10, 2022 Author Report Share Posted March 10, 2022 11 hours ago, kratmel said: So, as I understand it, Adam has to read data from the V570 RS485 (or RS232) and broadcast it to the Ethernet. Yes thats was the problem. But faced with the many problems, i connected them. now i need to know my AI register adresses. (MI200,MI201,MI202,MI203) Would you help me about this problem? Thank you sir. Quote Link to comment Share on other sites More sharing options...
baran Posted March 10, 2022 Author Report Share Posted March 10, 2022 I solved this problem. When you finished the rs485 to ethernet connection, open indusoft and add motcp driver. then in main driver sheet Station adress must be like this : ip:port number:modbuss adress (example 192.168.1.1:502:25) and MI0's register adress 4X:1 MI10's 4X:11 vs... have a good day everyone Quote Link to comment Share on other sites More sharing options...
