MUHANAD Posted March 27, 2022 Report Share Posted March 27, 2022 i am trying to make communication between vijeo citect and unitronics PLC but does not work when I use mode to scan it is OK i use express io device setup but we did not find unitronics so i use M340 modbus tcp ip but it dose not work how i can make this communication thanks Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted March 27, 2022 MVP 2021 Report Share Posted March 27, 2022 Hi, It is clear that SСADA is a master of the network. Then tell us which Unitronics PLC you want to connect and which communication channel. Possible variants of physical communication channels RS232, RS485, Ethernet, CAN, GPS. Accordingly, the communication protocol is possible MODBUS, MODBUS TCP. Maybe I missed something else. Clarify your task and I think the forum participants will be able to help. Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted March 27, 2022 Report Share Posted March 27, 2022 Also, I remember seeing an example for communicating visilogic controllers with citec scaada, on unitronics web site. It may work for you. If you are not still able to do it please share more information to give more advice on how to do. it Quote Link to comment Share on other sites More sharing options...
MUHANAD Posted March 27, 2022 Author Report Share Posted March 27, 2022 thanks for your replay when I change PC IP address from 192.168.0.223 to 192.168.0.110 the communication done PLC IP 192.168.0.134 modbus TCP IP Quote Link to comment Share on other sites More sharing options...
